Use the following procedure to create a static ARP entry.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Static multicast ARP entries are not supported for NLB Unicast or NLB Multicast operations.
